Sovkiller
Proved that despite its huge size the CD3000 can be shoved down one's throat.
- Jul 31, 2002
Yeah that's right they usually burned the coil or blow out the cone, etc... but not just die like a granma sitting there...check them the internal connections maybe is a loose wire or so or bad solder joint.....I have not tim for checking now the catalogs but is a few days if nothing comming up I will let you know....
