urs
Dear Colleagues,
I need the help of an electronics expert.
I own a CEC HD 53 R headphone amp, which has two independent amplification sections, each with plugs and volume control (but common inputs)
Due to a slight hearing imbalance, I would like to operate this amp so that the two amp section each supply the left or right channel respectively and hence I can use it to adjust the balance.
I prepared a suitable Y-connector with the appropriate plugs and common socket (according to my checks, it should be OK)
Actually, the whole device works [size=x-small]nearly[/size] as intended---
EXCEPT: The two channels are “out of phase” (as you would experience with reversed speaker cables)
This is quite puzzling, as I would expect that both amp sections are identical, with a common earth and equal L + R output polarity ?
Any idea, why this is apparently NOT the case ?
I checked both the chinch, as well as the XLR inputs, using a test CD that has “In phase” and “out-of-phase” test signals.
Thanks for your suggestion of how I could fix this problem – if at all--!!
Best regards
Urs
Best regards
Urs
