PDIP vs SOIC? Help with elementary op amp question....
Oct 12, 2005 at 4:39 AM Thread Starter Post #1 of 9
spinali
I guess everybody has to start somewhere.
I'm ordering one of the new SuperMacros and have my eye on several op amps. They seem to fall into two categories: PDIP and SOIC.
What's the difference between these two types of op amps? Can either be used indiscriminately as op amps with the SM3V6? Is there anything else that one should know?
Oct 12, 2005 at 4:42 AM Post #2 of 9
SOIC is surface mount - it has flat contact pins and is tiny
PDIP is through hole mount- it has bent pins, designed for inserting into IC sockets and such
You want the latter.
Oct 12, 2005 at 5:27 AM Post #3 of 9
A picture speaks a 1000 words
Oct 13, 2005 at 1:16 AM Post #4 of 9
The only reason that amp offers both choices is because some chips come in one package but not the other.
Oct 13, 2005 at 1:40 AM Post #5 of 9
I ordered some BUF634 in SOIC because mouser is running out of PDIP type, is there any way to sold SOIC chip on the socket?
Oct 13, 2005 at 2:07 AM Post #6 of 9
Browndog makes adapters for various opamp packages to others. For this you would want a single SOIC to PDIP adapter. Do a search for where to get them. It is possible to fabricate your own however.
Oct 13, 2005 at 2:43 AM Post #7 of 9
I'll try soldering first...
darn mouser and digikey run out of PDIO type...
Oct 13, 2005 at 8:44 AM Post #8 of 9
There back!. Its wierd isnt it how companies like TI work, a couple days ago, I checked the status of the buf634u, and it still said 12+ week leadtime, but I just checked mouser, and they are in stock.
Oct 13, 2005 at 4:43 PM Post #9 of 9
yes! but I already ordered them. Maybe it's more fun to play with adapter and those tiny leads than simply insert them into socket. PM replied...
