PCMCIA card with optical output
Sep 3, 2006 at 4:12 AM Post #16 of 30
Originally Posted by echo1
The Audigy 2zs is what I started with. Then I found head-fi. Bought a PVA2v2 to go with the Audigy.Sold the Audigy 2zs and the PVA2v2 and bought a Echo Indigo DJ. Then a tube amp.Waiting on a DA7.2 DAC from Eddie WU.Now trying to find a way to get it from my laptop to the dac.When will it end?
Hey, notice that I joined head-fi in the same month you did. When I joined, my setup was an iPod >> K701, no amp. I've been pretty progressive. Look at my sig!
Sep 3, 2006 at 4:23 AM Post #18 of 30
Originally Posted by steaxauce
Yeah, there are a few, and at least one affordable one; The Audigy 2 ZS. Unfortunately, the Audigy resamples to 48 KHz no matter what you set it to. Even if you set it to output 44.1KHz, it will resample to 48KHz and resample again to get it back to 44.1KHz. By doing this, it does a lot of damage to the digital signal.
How do you know this for sure? Has there been any listening tests to prove it's detrimental to sound performance? Or are you basing this off myths started on audio forums?
Sep 3, 2006 at 4:27 AM Post #19 of 30
If it's just a rumor, it's a pretty widespread rumor. But yeah, you're right. I don't know for sure. I own one, and when I bought the DA10, I was told that I should find another digital output, or I wouldn't get much benefit from the DA10. If y'all are interested, I can compare it to the digigram when it arrives. I don't have the means for a blind test, unfortunately.
Sep 3, 2006 at 4:39 AM Post #20 of 30
I would love to see the results. Honestly I don't care about that blind/non-blind/perfect testing atmosphere junk. Really I'm just curious if theres a difference or not. I'm planning on getting a DA10 soon as well, hope you're enjoying it
Sep 3, 2006 at 5:45 AM Post #21 of 30
Here is a link to some RMAA measurements that the author of the RMAA test suite has performed for the Audigy cards.
http://audio.rightmark.org/test/audigy/creative-audigy-rear-1648.html
http://audio.rightmark.org/test/audi...rear-1644.html
Have a look at the intermodulation distorton. This is an indicator of the distortions that happen when multiple frequences are playing at the same time (music!).
Another test that you can do for yourself is the infamous udial clip. But try this first at lower volumes until you feel comfotable you will not blow your speakers, headphones or ears.
udial.wav
A bit perfect and non resampled output to a DA10 produces an absolut black background in the dual tone test.
Cheers
Thomas
Sep 6, 2006 at 2:09 AM Post #26 of 30
Thanks, please report when you get the Digigram.
Given the Creative advertizing of Bit-Accurate playback at 44Khz, 48Khz, anbd 96Khz this is rather surprising. Have you tried this in the required high-performance mode?
Cheers
Thomas
Sep 6, 2006 at 2:25 AM Post #27 of 30
Will do, the digigram should be arriving tomorrow. I don't know how to test this, but a lot of people have said that it's impossible. If you know of a way of testing this, let me know and I will do it.
Sep 6, 2006 at 5:02 AM Post #28 of 30
A quick and easy way is to send a DTS encoded WAV file to a digital receiver.
http://www.sr.se/cgi-bin/mall/index.asp?programid=2445
If the card sends the stream intact the receiver will decode it into a surround sound stream otherwise it will be a hissing noise. You probably have some DTS capable receiver in your house or know someone who has.
If it works at all it will probably only work with an ASIO interface unless the mme/directsound drivers somehow circumvent the kmixer but this should be the same for the digigram card.
Cheers
Thomas
Sep 6, 2006 at 5:58 AM Post #29 of 30
If it works at all it will probably ony work with an ASIO interface unless the mme/directsound drivers somehow circumvent the kmixer but this should be the same for the digigram card.
Cheers
Thomas
... remember turn all 'extra' fearures OFF (EAX/CMSS/etc.) while doing this test.
jiitee
