dsavitsk
MOT: ECP Audio
- Aug 3, 2003
I am working on designing a non oversampling usb dac and could use some help with layout sugestions.
Here is the first go at a PCB.
Essentially, it is USB to PCM2707 to TDA1543. The I/V is just passive, and is a copy of the one used on diyparadise TDA1543 kit. There is also a Baby STEPS (TM) PS built in. The PS uses most of the steps design, but uses a LM7809 rather than an adjustable voltage regulator and also only uses one of the pre-rectifier filter caps and a very small version of the choke.
For PS connections to the pcm2707 I added space for 0805 decoupling caps figuring that I'd use 0.1uF ceramics, but I don't know if that's a good choice or not.
The 2 TO-92 things on the PCB are votage regulators (8V for the DAC and 3.3V for the PCM.)
Things that I know to be problems are dgnd is simply conected to the other grounds, and the connections to the PCM2707 got a bit messy.
The board is about 3.5" x 2.5" so there is not a lot more room. Any suggestions are eagerly anticipated, and I'll put up a schematic as soon as I draw one. For now, the only thing that is not self explanatory is the pinout of the pcm2707, but it is on the datasheet. You can also see this post from 00940 which is what I did.
Edit: fixed a couple of quick bugs in the layout.
