AllahLover69
- Feb 22, 2014
Hi guys,
I'm not very knowledgeable on speakers in general, and am looking to install an entry-level surround sound system on my PC. The motherboard sound isn't very nice, so I was planning on getting a Modi 2 DAC to clear up sound through my headphones. Given this, I need some advice regarding a few things:
1. Is it possible/effective to use my Schiit Asgard Amp along with a Modi 2 DAC to power a 5.1 or 6.1 setup? If so, how? and if not, what should I get to produce clear sound at a cheap price?
2. I currently have two good options I've found on craigslist. For PC speakers in my situation, which would you recommend Logitech X-530 5.1 Speaker System (https://www.amazon.com/Logitech-X-530-5-1-Speaker-System/dp/B0002WPSCG?ie=UTF8&*Version*=1&*entries*=0) for $75 or the JBL SCS180.6 6.1 setup (https://www.amazon.com/JBL-SCS180-6-6-1-Channel-Discontinued-Manufacturer/dp/B0006N14ME?ie=UTF8&*Version*=1&*entries*=0) for $50?
This will mostly be used for music (Hip-Hop, Rap, Rock, Punk, Alt, Electro), but also for streaming videos and TV shows (so bit-rates for that will be relatively low). I have no idea if it is possible to set up what I want using my headphone amp/DAC setup (I want to switch them off to power both my HD 598's and my speakers), or if it will power it sufficiently. My current thoughts on the speakers is that the Logitechs might be better for entry-level especially without a dedicated speaker amp/DAC, and the JBLs seem nicer, but might take more to power. I really don't have any experience with buying or setting up speakers, so any answers or advice to my questions will be greatly appreciated.
Thanks so much!
Thanks so much!
