Originally posted by venzuel00
How does the NAD L40 compare to your C320? I can't find yours, i can only find the C350. |
Ooops, I meant the C350. (The C320 is an older NAD amp, it's fairly well regarded but not the one I have.) From what I understand, both the L40 and C320/350 are descendants of the famous NAD 3020 integrated amplifier, which was very popular for a number of years. Obviously the C350 is more powerful, and you can add a separate preamp if you want, but the L40 is also well regarded, and might be all you ever need. Plus the L40 comes with a CD player and tuner. You can listen to CDs through your computer's CD player, of course, but it's sometimes convenient (parties, etc.) not to have to do this.
NAD amps generally all have good headphone jacks. In my opinion (people will argue!!) the headphone jack of the C350 drives the Sennheiser HD600 particularly well. It is reasonable but not stellar with Grados, and decent with Etymotic ER-4S. I also have two headphone amps: a Melos SHA-1 and an MG Head DT OTL. To be perfectly honest, I prefer the HD600 with the C350, rather than a dedicated headphone amp, but I'm probably the only person on this board that feels that way. The other headphones do benefit greatly from dedicated headphone amps. The MG Head / Etymotic combo is particularly good (more satisfying than my speaker setup).
If you live in a noisy dorm, think about Etymotics! They will reduce your stress level about a thousand times. (If you often work in noisy computer labs, your grades might even improve. There is something to be said for isolation and concentration!) The internal sound chip of the ThinkPad T20 is the wonderful Crystal SoundFusion, which is powerful enough to drive even the Etymotic ER-4S without an additional amp. It's actually really very good. You sacrifice a little bit on the low end (bass), and a bit on the top end (treble) compared to the Stereo-Link with a dedicated amp, but I definitely only mean a little. Overall the ThinkPad T20 by itself is a very good source for headphones. It is also incredibly convenient on the go.
Did you know that if you get one of the two IBM docking stations/port replicators, you will get a line out from the laptop? This is also fed by the Crystal Soundfusion, and it does sound very good. If your budget is tight, you can avoid getting the Stereo-Link by using that line out. Unfortunately, depending on what hard drive you have in your T20 (I have the liquid mercury 40GB ultra-silent), you may get a "chirping" sound occasionally on the line out. This is why I ended up going for the Stereo-Link. But the chirping isn't horribly annoying, and I did live with it for some time. Otherwise, the line out sounds very good.
