ohhgourami
- Apr 16, 2010
I spent much of the beginning of the week with my current computer figuring out why I had issues with my audio drivers (generic usb audio) for my USB to SPDIF converter. After fiddling with more things I realized my issues were from my fans. In the BIOS setting for my fans, when I turn it down from "turbo" to "silent" mode, my audio drivers would have no issues. Today when I added another fan to a 3 pin header, the same problem came back. Same issue even happens when I have it directly to my PSU. It even does that start-stop thing during boot up if I pushed my OC too far. I switched to a lower power fan and everything went back to normal. I'm guessing my problems come from so sort of power issue during boot up that causes my USB port to not have enough power resulting in a bad connection leading up driver errors.
Here is the specs for my rig:
i5-2500K OC'ed @ 4.5ghz
Asus P8Z68-V-LX mobo
2x4gb ram 1600mhz
Seasonic X-750 watt PSU
HD 6850
2x SSD
5x 120mm fans
My PSU should have more than enough power so I don't get why this is happening. Please help.
2x4gb ram 1600mhz
HD 6850
2x SSD
5x 120mm fans
