FireDragon76
I've had microphone problems on my PC for years. At first, I thought it was a PSU issue, then a room noise issue, now after some testing I think it may be due to something about the computer in general (perhaps the PSU). I tested the same microphones (MEMS headset mics and an electret condenser) on another PC that has a high end MB and power supply, and there's about a 9-10 dB difference in the signal to noise... all presumably electrical (I moved the PC out of the noisier room).
My current power supply is an Antec Neo Eco Gold Zen 500W bought during the early part of the pandemic (summer 2020). It replaced a ten year old Antec 450W. It didn't seem to improve the noise. My motherboard is an ASUS A320. Low end but not junk. The headphone output is decent and that's all I use now, I got rid of the Soundblaster AE-5 because the microphone input was actually worse than my motherboard. I can crank up the MB audio and the background is completely black even at very high volumes I'd never listen to. Which is impressive as MB audio used to be pure junk years ago.
I use NVidia RTX and even it was unable to clean up the audio from the Soundblaster. I love RTX but it's a beast (a significant performance hit in any kind of 3D gaming) so I am trying to use lighter solutions like RNNoise. And RNNoise seems to have particular problems with the noise of my PC (it works perfectly fine on the other machine I tested).
I also have a Rolls preamp and a larger electret microphone, as well as a high end boutique preamp and some dynamic microphones (probably my favorite, but difficult to drive). The line input on my PC works fine with all of them. The Rolls has a fair amount of noise with a dynamic microphone, because it's made of cheap stuff, but it works great with headset electret mics and so I just used the Rolls for a while connected to my headset mics and it did reduce the noise a fair amount. But I'd prefer a simpler solution.
