AuroraProject
- Jun 13, 2004
No, there are dual 80's in, an 80 out on the mobo tray, an 80 out on the psu, and an 80 out blowhole. I'm considering adding another 80 to the side panel blowing onto the video cards.
Originally Posted by wallijonn 42cfm may be too much. All you really need is about 17 - 25 cfm. My PBZ used to overheat even though I had a 127cfm 120mm fan installed on the intake and two 40cfm 80mm exhaust fans. I then installed a 120mm heatpipe hole, installed a 70cfm 120mm intake and 70cfm 120mm stovepipe exhaust, removed the 80mm fans, blocked the 80mm holes, installed a 70cfm 120mm and my temps dropped 25F. I then added the XP120 and a Silverstone 20cfm 120mm fan and my temps dropped another 15F. I idle at 100F, Zone 1 at 93, zone 2 at 90. So if you can remove the top of the case (even if you have to remove the rivets) and then do a mock up with cardboard with a CD hole in between the PSU back and the CDRom back, then measure the temps. Is your intake fan 120mm? |
