Hello guys,
Complete newbie here... but since it seems that everytime I am searching for audio answers, I end up here so I finally signed up...
Hoping for some guidance here with a PC audio issue(microphone).
Unless someone has any suggestion for my microphone issue, I am going to be replacing my on-board audio with some kind of device that I could use help choosing.
Quick rundown of issue: microphone is very quiet and often produces hissing/static. Tried every possible setting, updated drivers, tried front and back ports, tried 3 different microphones. Only usable setting is 100% mic volume and 20-30db boost but even then it is hard to hear my voice.
This is on Win10 with ASUS P8Z77-V DX mobo (Realtek ALC898). Maybe onboard chip has issues?
I spent quite a bit of time trying to figure this out now and thought that maybe simply moving to a dedicated device would bypass the issue.
I am scratching my head in deciding what would make a good replacement. My needs are pretty basic, I want to decent sound quality (for my newbie ears, the onboard sound is currently fine for me with my Superlux HD681 EVO), and I want to fix my mic issue. I don't mind spending 0-100$ to improve my setup. I plan on eventually moving to better headphones as well.
This is 100% desktop use, USB ports are not an issue but PCIe internal slots aren't either.
My uses are: light gaming, music (google music mostly, some mp3, some lossless flacs)
So I saw a bunch of devices that could work and I am a bit lost:
- cheapo 3.5mm to USB adapters that would bypass the onboard card
- cheap USB sound cards like sound blaster play or xonar U3
- Higher end USB sound cards like U5, Sound blaster omni
- Internal cards like Xonar DGX, Sound blaster Z
Now when searching for recommendations I often see the "never buy a sound card, get a DAC/AMP", but this is a world I know nothing about. Would that be an option for me?
I looked at a couple of entry-level USB dacs that are often recommended (Fiio, etc) but they usually don't have a mic-in port and this is the main reason why I am looking for a replacement so I don't know.
What would you guys do?
THANKS!
THANKS!
