Passive Summing Box/Cable Resistor Question
Jan 28, 2014 at 10:31 AM Thread Starter Post #1 of 2
Senpai3330
I read the "Wye" Not Rane note on summing boxes. The diagram above is taken directly from their discussion of a stereo-to-mono summing cable.
What determines the resistor value that connects the +signal to the signal ground? And honestly what determines the 2 resistors in the +signal path?
I will be using it to sum stereo preouts to a single LFE input on an active subwoofer.
Feb 1, 2014 at 1:38 AM Post #2 of 2
The exact values aren't terribly crucial. The resistors on the + path are just to prevent your L and R from shorting into each other. Anywhere between 100-1k ohm is fine.
The resistor to ground isn't entirely necessary, but is an extra "foolproof" step . To prevent too much loss, that resistor (or your input impedance, whichever is smaller) should be at least an order of magnitude bigger than those on the + wires.
