tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Very entertaining and useful, Tangent!
Originally Posted by Voodoochile ... snip ... I once saw a fairly detailed article about some guy who made a heatsink for a graphics card out of the better part of a roll of pennies. It was just plain scary looking. |
Originally Posted by Voodoochile Well tangent, I guess you are all caught up on other projects, eh? |
I was half joking when I suggested the epoxied penny. I don't think it's a good idea. |
Although the contact area would be far from optimal, it's a lot better than a paperclip. |
And then the thought of the paperclip falling off, and landing somewhere around the legs of the reg... |
Of course it's best to buy a proper heatsink |
Originally Posted by tomb Not quite as scary as the thing that guy in your avatar built |
Originally Posted by Tangent I think the reason the paperclip does so well is that it has a lot of surface area away from the regulator, in contact with the air. Most of the surface area of the penny is just mimicking the TO-220's tab, so no advantage. |
Originally Posted by luvdunhill I'm looking to step up from the 24.4 C/W heatsink recommended on the TREAD by Tangent, and was thinking about using this one but mounted "the wrong way" (i.e. the fins sticking out away from the board).. this gets my thermal resistance down to 9.6, but I was wondering a couple things: 1.) Does this really matter since I will not be using a fan, so I will not have any air velocity (see the graphs for the part above) 2.) Is there another heat sink that would "fit" on the TREAD? The larger style used on the STEP doesn't look like it will even come close to fitting!! Thanks! |
Originally Posted by Nordic I was testing my valve pre one night when my wife asked me why the tube was glowing so brightly, which surprised me as it was an ecc88 and they don't realy glow like that... or none that I have seen next moment I got the hot electronics smell from the regulator board supplying the 6V heater.... I forgot to attach the heatsink... and it swung to full voltage output... luckily it didn't do any permanent damage to the valve or the regulator. |
Originally Posted by Garbz as a matter of interest what is your background in statistics? It seems you know quite a bit about data samples and expectation. |
