Panasonic: Difference between SLCT710 and SL-CT810?
Sep 22, 2004 at 3:31 AM Thread Starter Post #1 of 4
Spitzfiya
Does the SL-CT810 sound better then the SLCT710? I am in love the SLCT710 I just bought, Its so thin and sexy, and the remote is so small and easy to use. If the SL-CT810 sounds better or has better quality parts ill return my SLCT710 and get the SL-CT810.
SLCT710:
http://www.futureshop.ca/catalog/pro...6&newdeptid=19
SL-CT810
http://www.futureshop.ca/catalog/pro...&newdeptid=19#
Panisonic has some nice F-in PCDPs!
So what do you think, is it worth it?
Sep 22, 2004 at 3:48 AM Post #3 of 4
I used to have the SL-CT710, but mine broke
But I didn't really like the SQ out of it anyways. It might be worth while to invest in the 810 since I think I've heard around these forums that the Panasonic high end ones are significantly better than the lower models. Even if it isn't that much better at least you don't always have to wonder =)
Sep 22, 2004 at 3:59 AM Post #4 of 4
I don't use the EQ at all, but if it has higher quality parts then awesome, ill pick it up. I'm using the HD-497s and I notice the sound coming out is slightly dull almost like its behind a thin curtain. But in other areas it sounds better then my other sources (Computer/Foobar/Crappy stereo)
