oddity
- Sep 28, 2009
Carrying around full-sized cans while on the move is really impractical. I tried using Koss Portapros but I gave up on them as they are uncomfortable for me, not to mention too ugly for words.
So that leaves IEMs, which for me is a problem.
I sustained some pretty serious ear damage during a deployment to Iraq. I had my ear-drums ruptured twice by explosions, causing a build-up of scar tissue in both my ears.
This scar tissue has made my ears hypersensitive to pain; standard IEM tips become uncomfortable very quickly, and inserting triple-flanged tips is agony. It helps quite a bit if the IEMs have an over-the-ear thingy to take some of the weight and pressure off of my ear canal.
So here is my three part question:
1) What IEMs ($100-175USD price range) with an over-the-ear thingy would you recommend for my situation?
2) Do you think that getting a set of custom molded ear pieces would help, and if so, where can I get it done/buy a kit?
3) Besides custom ear peices, what are some really comfortable ear tips?
Thank you for any help you can provide!
