syNRG
- Feb 14, 2012
Hi everyone
I'm looking for new pads for the Audio Technica Pro700MK2 headphones since the stock ones are just super uncomfortable.
So far I know that the M50 pads work. But I did some reading and someone said that you need to "glue" the pads to the haedphone as they fall off after extended use?
Anyways, since the M50 pads work on the Pro700MK2, and the Shue SRH840 pads work on the M50, will the Shure SRH840 pads work with the Pro700MK2?
If you have any other suggestions other than velour pads that aren't too expensive would be great
Thanks
Thanks
