Owner Sony Discman D-66, Help!!!!!!!!!
Nov 27, 2005 at 4:04 AM Thread Starter Post #1 of 10
manoppo2
Hello Everybody,
i just got D-66 from Ebay without AC adaptor.
could anybody be kindly to tell me what AC adaptor i need to get?
i mean like Volt, polarity, mA for out put.
TIA
Nov 27, 2005 at 4:56 AM Post #2 of 10
I don't own the unit, but many items that have an AC adapter input either have the voltage requirement/polarity printed or in raised plastic near the input.
Maybe that isn't the case with the D-66 but might want to break out the magnifying glass and have a close look.
Paul
Nov 27, 2005 at 8:42 AM Post #3 of 10
It probably needs a 9v adaptor like the D-35 I have; although, I don't know for certain.
You're the guy who outbid me on that Aiwa XP-55 I wanted at like 15 seconds to close!
Oh well.
Nov 27, 2005 at 1:16 PM Post #4 of 10
Originally Posted by manoppo2
Hello Everybody,
TIA
According to the manual, it should need a 6 volt adaptor with the centre of the plug positive.
There is a note in the manual that says you should not use the adaptors for other Discmen that use 9 volts.
Nov 27, 2005 at 3:58 PM Post #5 of 10
Hello again,
if you read that manual there're 2 AC adapter one 6 V and the other 9 V.
which one the right one?
i tried both of them nothing work. display only shown 00 after couple second shut off by itself.
the seller stated that player is new(with missing AC adapter).
i just suspect that player is defective.
any suggestion?
Thanks to Everybody that give me quick response.
Filburt, i'm sorry Man to outbid you on XP-55, next time i'll promise to stay away when i see xp-55 show up again.
by the way this player is superb in sound term(IMO), you won't regret it when you get this model.
Nov 28, 2005 at 4:43 AM Post #6 of 10
Hello again,
any suggestion?
Thanks manoppo
. Could you describe in a little more detail what it does when you try to play a CD?
Nov 28, 2005 at 10:06 AM Post #7 of 10
On a related note, I tried a Sony 4.5v adapter with my D-33 (requires 9v) and believe it or not, it worked... yes, the batteries were removed when I tried it. Just about blew my mind, but I guess it makes sense given the player runs OK on four 1.2v batteries. Wouldn't want to run it at that low a voltage tho, possibly restricts dynamics or causes other issues.
Nov 28, 2005 at 7:29 PM Post #8 of 10
Manoppo2,
Take a look at the ac jack on the D-66, near to the ac jack on the D-66 there should be an indcation as to wether your D-66 takes a 9v or 6v adapter with a negative (-) or postive (+) polarity tip. Since you have mentioned that your D-66 powers up after trying a ac adapter and that the lcd display shows 00 then shuts off after a while indicates that your D-66 may be faulty. If you tried to play a cd and the lcd displays 00, it indcates that the laser is unable to read the cd for some reason or another.
Nov 29, 2005 at 2:06 AM Post #9 of 10
i just came back from sony service center.
It's confirmed that faulty from lense like warubozu said.
to fix it will cost me fortune.
Filburt, xp-55 is really beast. it reads CDR, CDR-W.
this player is underated not so many head-fier mention it.
Nov 29, 2005 at 6:33 AM Post #10 of 10
Manoppo, glad to hear it on the Aiwa. Unfortunately, the XP-55 seems to be a rare find nowadays on eBay. Hence my disappointment on not getting it!
Open the D-66 up and adjust the Tracking Balance first, then maybe the Tracking Gain, Focus Gain, and Focus Bias. On one player, I had to adjust every pot on the cd player (including the PLL) to get it to work correctly.
Hopefully, you'll be able to salvage the player.
