velogreg
- Dec 6, 2005
Gontran is on to something.
Try using the blinking LED's from RS hooked up to two AA's. I did this a while back for my son for one of his projects and the battery drained in less than 24hrs. So multiple LED's should get you in the timeframe you desire. As for time to drain, RS had somewhere a light sensing meter or probe, similar to the on at dust lanscape light sensor. Just place the LEDs and sensor in a closed shoe box, run the wires through the wall of the box to the outside. When the LEDs run out of juice, the LEDs go dark the sensor goes on, note the time.
Voila! You get to keep your job.
Good luck.
Greg
Good luck.
Greg
Originally Posted by Gontran /img/forum/go_quote.gif You could also put a power resistor in paralel with the fan or motor. You can find blinking led's at mouser, digikey, maybe even rat-shack, or one of those pretty multi-color flashing LED novelty things people hang from earrings and other body piercings...(I'm sure there's a name for those, I don't get out much...) or those spinning ever changing LED thingies they sell at the amusement parks (around central FL anyway...) |
