sorrick
- Dec 6, 2006
So I just got Trailli, have the Odin, and have been comparing them since the Trailli arrived yesterday morning. I’m still getting to know the Trailli, and I know that I need more time with it to get a holistic sense of its full capabilities (this would be true of any iem this soon after getting it, but I can tell already is particularly true of the Trailli because some of its greatness clearly lies in how well it does certain subtleties.Can someone who has owned both tell me how far the Odin is off the Traillii’s pace? And if so, what music genres do you listen to and find best with the Odin vs. the Traillii.
I listen to a little bit of everything—pretty much anything with the exception of country—and I’ve been listening to a bit of everything over the past two days as I’ve been putting Trailli through its paces. This has included classic rock (Rolling Stones, the Doors, Cream, The Who, The Band, etc.) Prog Rock (Pink Floyd, Rush), acoustic/singer-songwriter (Martin Sexton, Carole King), Electronic (Daft Punk, Prodigy, Crystal Method, Caravan Palace), dubstep, hip-hop, contemporary pop, electro swing, etc etc.
I would certainly say that as a whole the Trailli is better, but at least to my ears, we’re not talking night and day differences. However, the sum of the differences adds up to a overall improved sound in most areas. For me it’s enough to justify the substantial additional investment, but that’s an entirely personal opinion.
On technicalities (particularly resolution, micro and macro detail, soundstage depth) they are actually very close and there are some areas where the Odin reigns supreme. Odin’s tuning accentuates it’s clarity, detail, separation and precision through its emphasis on subbass over midbass, and upper mids over lower mids. The Trailli has more midbass and lower mids, which give notes additional body and adds a naturalness. It matches or exceeds the Odin’s detail, layering, but does so in a more effortless, less emphasized way. In fact, effortless excellence is a really good two-word description of the trailli.
To my ears, Odin edges Trailli out in its delivery that subwoofer-like thump subbass impact at the leading edge of a bass note—there’s a certain robustness there that the Trailli doesn’t quite match. I’m not talking about quantity, because Trailli actually has at least the same about of subbass if not a little more, but the subtle quality of that leading edge of impact that the Odin’s dual weapon ix+ dynamic drivers offer that is really satisfying. However, Trailli is, somewhat shockingly, within whispering distance here—it really has a dynamic driver-like quality to its bass—and matches the Odin on bass texture and realistic decay, while also being a little tighter and faster. Trailli has noticeably more midbass quantity, impact, fullness, and texture, but does this without any bleed or bloat into the mids at all, which is quite the trick
As I mentioned above, the trailli is more balanced in terms of lower mids and upper mids, and the increased lower mids add more body, warmth, and organic naturalness. The Odin is comparatively more neutral, less bodied, with more of an upper mids emphasis that can occasionally add a subtle nasal-y quality in certain circumstances. The trailli matches and perhaps exceeds Odin in terms of detail and I would say exceeds it in terms of texture in the mids, though some of this is less immediately apparent because the effortless presentation doesn’t emphasize these qualities as much.
Both have excellent treble, but the Odin is overall a little smoother. The trailli’s treble really is something special with an edge in detail, texture, sparkle, and shimmer but, again, done in a very natural realistic way without overt emphasis. There’s no hint of sharpness or stridency, in either and Odin’s treble really is excellent—the best I had heard until trailli, but trailli edges out the Odin in subtle ways here that just sound a little bit more natural when going from one to the other.
On soundstage, both are again excellent, but the Trailli is noticeably wider and taller. They match each other with fantastic depth.
One dig against trailli so far is that the cable is pretty stiff and less comfortable than the stormbreaker cable on my odins; however, i expect the trailli cable to become less stiff as I use it, which happened with my stormbreaker. Trailli cable is also noticeably more microphonic, particularly when part of the cable rubs against itself or you move the chin slider. These are purely ergonomic issues though.
However, the sum of everything makes the whole of the trailli, to me, a noticeably better iem, but we’re in such a high echelon of performance here, that both are excellent—trailli just has an effortlessness and naturalness to its performance that is really compelling and astounding. It’s like the difference between two top professional athletes, one (the Odin) that works harder than anyone else and as a result has excellent, almost textbook technique, while the other is just insanely naturally gifted and has an innate effortlessness and almost perfect instinct (trailli).
