Now that I have ranted so heavily let me post some constructive ideas:
PRICE RANGE: $1,500
PURPOSE: Music listening/burning, performance-intensive apps, and general entertainment.
1. Chieftec / chenming case.
Make it a server-size so you can buy this insane chipset that I will talk about later. ~$60-$120 or so depending on options.
-4 Optical (CDROM-type) drive bays
-Room for 4-6 HDDS and 2 floppies
-Holds a server chipset which means blazingly fast speed
-Easy to work with, very innovative designs (side of case pops off in seconds, rounded edges, drives pop out easily, etc)
2. 431w Power Supply or greater.
Go all-out in case you ever decide to turn it into a server. Plus it aint that bad; $100 or so for a good enermax PSU with a fan controller.
3. Intel 875P Chipset.
Buy the intel version (other manufacturers also make this chipset). Blazingly fast. Comes with JEDEC standards built-in (thank God) for DDR. Runs up to 4GB of DDR400 at spec! Amazing board. Also has serial ATA, support for 800mhz FSB or 533mhz FSB. This is good stuff. $180.
4. Intel 800mhz FSB at 2.8 GHz.
You'll notice I listed the FSB rating before the GHz. . . it's that monumental a number. Processor clock is now second compared to the other features a processor has. This processor has received rave reviews from gaming sites and is at an incredible price. $300 with FREE SHIPPING at NEWEGG. This is a highly recommended component.
5. Western Digital 120GB 8MB Cache 7200RPM ATA/100. This speaks for itself. $120.55 at newegg.
6. ROUNDED ATA/133 cables. Your choice of colors, flavors, etc. Get the 36" ones if you get a big server tower, otherwise the 24" ones. You'll need one ATA cable for every two optical devices or hard drives.
www.case-mod.com. Like $5.00 per cable.
7. Corsair TWINX1024-3200LLPT 1GB DDR400 XMS3200.
www.googlgear.com. $280.00. You're getting a gigabyte of RAM in two sticks of 512MB. This stuff is designed around a dual channel chipset and will perform optimally. Designed to run natively at the DDR400 spec of the chipset I recommended.
8. Geforce4 Ti4800SE with Video/DVI by MSI. I find the Ti series, while slightly outdated, to be very solid performers and are EXTREMELY stable. They come with no weird software and the MSI versions can be overclocked very easily without coolbits or tweaks. Cost is very low. You're getting 80% of the performance of a top notch card which will run you much more cash. $160.00.
We use the theme of synergy when designing our headphone systems. I find it applies to everything in real life, especially computers. Why not make a system in which all the barriers to true performance have been broken? my suggestions total $1,250 or so.
That leaves you $250.00 for any sort of DVD/CD combo drive you need plus a really nice PCI sound card.
Computers are quite an obsession. Not comparable to the audio obsession, however....
Cheers,
Geek
