devwild
- Mar 28, 2004
Your statement does not pertain to optical equipment. Do some reading on optic networking, where quality of cable most certainly makes a difference even with short jumpers. Tremendously higher standards than toslink though, and multiple technologies.
Different quality toslink cables have a visible difference to their transmision quality (due to clarity, and dispersement), not just audible. There is most certainly a difference, one that can make it difficult to get a proper signal lock at all if you use a cheap cable.
Originally Posted by Sycraft Please note, there are audiophiles that disagree with the folowing. That said: One cable is as good as the next. There are no problems with interference. It either works, or it doesn't. The only reason for higher quality cables is less signal loss for long runs, and/or better flexability. On short runs, it doesn't matter. You can do 10gig ethernet, which is clocked in the gigahertz range over whatever you like at short range, audio is not a problem. Unless there is something difficult about your run, buy whatever you like. It's all digital, all optical, it doesn't matter. |
