emmodad
- Apr 8, 2007
recognizing the limitations of using an external hard drive with the USB input of Oppo players (FAT / FAT32 formatting; somewhat limited number of files recognized), I'm curious: can anyone share experiences using the Oppo USB input for playback of disk-based audio files? Specific interest here is hard disks or SSDs, not just small-capacity thumb drives.
What format of digital audio files are you using?
Are you successfully using uncompressed wav or aiff?
if sourced with uncompressed files as wav or aiff, it would seem that this could be a path for hardware-based HDCD decoding for disk-based playback... recalling that the 980H HDMI output carries 24/88.2 decoded HDCD (which can be legally extracted), this could be a low-cost option to feed decoded HDCD to your DAC of choice.
