nwavesailor
- Nov 14, 2009
FWIW, I haven't experienced any interference with my HA-2SE.
Nor have I, but I am also not using it with an iPhone or Android.
I almost pulled the trigger on a Chord Mojo till I noticed it doesn't have line out either.
Hold down the volume buttons when turning on and the output level is set at fixed line level.
Hmmmmmm...
I am now more undecided again.
Do you have any experience with using the Line Out to run desktop amps from a PC?
I use the Mojo to run a secondary system.
Computer USB or Toslink--> Mojo--> Cavalli Liquid Carbon
It works really well. Put the Mojo in Line Out mode and give it external power and you're good to go.
I'm still debating the Mojo now. I was more set on the Oppo until I found out that the Mojo does have line out. The new problem is that the Mojo doesn't have line in. The Oppo HA-2SE has everything I need except the power to effectively drive all my cans by itself. My phone doesn't support UAC 2.0 via USB OTG yet so I couldn't even use the Mojo while traveling with it. I could run it off my Surface while on the road, but that is hardly desirable over my phone. I could also convert the audio out of my phone from USB OTG to optical, but that adds another device in my audio chain.
What to do?
I guess it's about what you want the most. No doubt the Oppo HA-2SE is a feature packed devices that can connect to anything - and it's a great design that packs nicely with a phone - it's sound quality is ok for the price considering the features. If you want something that is mobile and versatile the HA2-SE is great (unless you have an iPhone and travel a lot) .
However - if you value sound quality over features and have the money for it you should get the Mojo (there is a quite a difference because of it's fpga dac tech - no hiss, wider soundstage, clearer separation - and lots of power - using it with my HD800/6xx's). And if you are going to use it with external amps on the desktop I would get the Mojo - no doubt.
What phone do you have?
I did recently post this in the sponsors HA2SE thread but didn't get a response and Oppo UK unhelpful, so re-posting here in case someone from Oppo sees it.
Yeah, I was well annoyed the HA-2SE was brought out very shortly after I bought the HA-2 and rapidly developed a fault. "Power bank" feature not working and battery failing to charge/depleting within an hour. Need to return it but been in and out of hosp since September including two major abdominal surgeries. Feel punked, would even pay the upgrade fee. Was thinking of getting a pair of PM-3 but considering my options now.
What's keeping me on the fence right now is that I don't know what the Oppo can do with my planars and 600Ω cans. I don't want to buy something that is versatile, yet not usable with all my headphones.
I don't think it will have enough power. When I was using it with my 300 ohm HD65xx it was on high gain and turned up quite a bit to get an ok level.
I wouldn't use it with 600 ohm (I also think they only recommend it for up to 300 ohm headphones).
