Penarin
- Feb 13, 2012
I use Grado 125s for PC gaming and music. Great sound all around.
If you're on PC audio, I wouldn't recommend the Essence STX with the Beyer's - too much oomph. But who knows maybe you'll like it.
I ended up pulling the trigger on the DT990 Pro. There is a considerable price difference between them and the DT880s, and I think I'll prefer a set with a little more color than the 880s which are evidently very neutral.
Thanks for all the input.
I think you made the right decision. I don't think you'll be disappointed. They should serve you well for the money you paid.
Also to answer your question about vocals, I don't think they're in any way recessed in and of themselves, it's more like the rest of the music is playing around it but not drowning vocals out. And in songs where the emphasis is on vocals anyway you won't have issue with them sounding dull or anything.
And to the guy saying the Essence is basically the same amp as E9 - are you sure ? My DAC must be making all the difference then.
The Essence STX uses basically the same headphone amplifier as the FiiO E9. If there is any major frequency response difference, check the EQ or other DSP settings
arg I would rather step on those horrible JRC opamps, all the harshness and bloated muddy bass disappeared when I put other opamps in, TH4032, AD797, list goes on
I guess the O2 must be really poor then, since all the op-amps in it are JRC, even the comparator in the power management circuit
To be honest, I demoed the D2000 in the local high street and the first thing I remember saying to myself is that they sounded similar to my DT 990 Pro's I mean they weren't wildly different to me. Build quality wise they're both seemingly very good, but you must remember that the D2000 has had many reported issues with the screw that connects the earcups to the frame of the headphone - that and the fact that it's almost double the cost of the DT 990 Pro - and also comfort wise personally I'd say the D2000 shades it as that headphones just slides onto your head with ease but again not worlds apart.
In the end there's not much in it in my opinion between the two, and it all comes down to price and if you are willing to spend double the money I guess.
Also in my opinion the DT 990 Pro's are amazing for gaming and movies, especially blu ray, I would say that you'd be hard pressed to find a better headphone for these purposes especially for the money - I'm definitely going out on a limb with that statement as there's lots of competition - but they really are very good for gaming and movies.
