RPGWiZaRD
- Jan 31, 2010
Here's a strange matter with probably an even more difficult answer;
I'm looking to use onboard audio, specifically I'm looking at the new Intel Z87 boards with the latest Realtek ALC1150 chipset. Some motherboards offer onboard op-amps that usually push up the "SNR rating" from 112dB to 115dB. I have already built a new system but I want to exchange my motherboard ASRock Z87 Extreme6 versus either:
ASUS ROG Maximus VI Gene (mATX) http://www.asus.com/Motherboards/MAXIMUS_VI_GENE/
or
ASUS ROG Maximus VI Hero http://www.asus.com/Motherboards/MAXIMUS_VI_HERO/
Both use the latest ALC1150 chipset. The Gene features onboard op-amp (TI (RC)4580) and Hero doesn't use one, this seems to be the only difference audio-wise minus the layout differences. What's your thoughts regarding onboard op-amps on motherboards, good or bad from a noise, more specifically EMI noise interference standpoint? I understand an op-amp should even eliminate some noise if configured correctly but what about if the noise is bleed into the chain AFTER the opamp and before the analog outputs? Will it actually also help to further amp up the noise levels then or how does it work?
My ASRock Extreme6 features onboard opamp TI 5532 with the same ALC1150 chip and on this board the EMI noise is annoying me if I'm using my ZO amp, well even without it I can hear a little bit noise (especially popping) but with the amp if turned up high on the volume on the amp the noise is very audible (HDD activity, mouse, high system load etc). On my previous ALC889A audio solution with Gigabyte P55-UD5 it was borderline acceptable also with max amp volume.
Which of the ASUS Gene vs Hero would you put your money on producing less EMI noise if only going by "paper". I really want to buy one of the boards and I'm not too keen to try both to get the definitive answer. For me low EMI interference has higher priority than the output quality in this case. I have no idea about these things why I'm hopefully finding some expert on this board which may have a better understanding about this topic.
or
