tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
I'm sorry I offended you. I'm not trying to be insulting.
To understand this breakdown between us, it is not important which of us is right. All that matters is that I understand this circuit differently than you do. If I had no concept at all of how it worked, I might just take your statements without question. The problem is, I do have a mental model of how it works, and that model makes sense to me. It may not be a correct model, but I haven't yet seen anything that makes me change it.
In this sort of situation it does me no good to take without question things you say that go against my understanding. That would crush my curiosity, stop my learning process, and turn me into a jeffreyj hero worshiper. Not that there's anything wrong with jeffreyj being someone's hero. It is simply unrelated to the practice of engineering, that's all.
Given that I understand this circuit differently, I must question things you say that go against my understanding. You can:
1. ...take my response as the unschooled piker telling the Real Engineer that he's a blithering idiot.
2. ...try to explain it a different way.
3. ...decide that it's too stressful to try to communicate with an unschooled piker.
If I thought you were an idiot, Jeffrey, I'd just stop replying. I'd have no incentive to continue. I'm still participating in this thread because I do respect your knowledge, and I hope to resolve this question.
I do not possess all of the mental tools or experience you have, but I'm willing and able to learn. That should be enough.
Still with me? Okay. Allow me to explain how I think this circuit works.
Let's begin with the Jung circuit, but with the diode removed. What we have now is basically a Sulzer variant with the pass transistor's collector connected directly to the raw supply, and a CCS which is just being a nuisance. (I'll get to that in a bit.) There are some different component values and we're using some improved component types, but basically it's a Sulzer regulator at this point, right?
Let's say R1 and R2 are 1K. The op-amp slews to put out 2Vref + Vbe. The drop across the pass transistor puts 2Vref at the output of the regulator, which balances the op-amp's inputs.
Now imagine some 120 Hz ripple on the raw supply. We'll assume that the PSRR of the op-amp is infinite, so the only thing that happens is the ripple gets through the pass transistor without much attenuation. This ripple appears on top of the 2Vref output voltage, so as the ripple voltage rises, the op-amp's output voltage goes down, cancelling the ripple. Vice versa when the ripple voltage starts dropping again.
The CCS, as I said, is just sitting there being a nuisance. The CCS current splits among the op-amp's output and the base of the transistor. The current going into the base of the pass transistor probably will make it saturate, as you said above, but Vce doesn't really matter here. All that's important is that the emitter remains one diode drop below the base voltage. The base of the pass transistor is at 2Vref + Vbe despite the current being driven into the op-amp's output. The fact that the op-amp is sinking current may affect its performance, but as long as the current level is within a reasonable range it doesn't make the op-amp deviate from maintaining 2Vref + Vbe at its output. Hence, the regulator's output remains 2Vref despite the current source's action.
I apologize for taking so long to get to this point, but I wanted to make certain that I understand everything, and that we agree on the basics. Now let's throw the proverbial monkey wrench into the works: the diode.
When the ripple voltage rises, the op-amp's output voltage starts dropping. The pass transistor's base is now one diode drop above the op-amp's output voltage. (Yes, I'm ignoring the 10 ohm resistor's drop.) The emitter is a diode drop below that, so now when the op-amp's output voltage goes to 2Vref, the regulator's output is also 2Vref, right?
If all this is correct, the system is still voltage-controlled. It's true that the op-amp will only sink current with the diode there, but when the op-amp's voltage moves, does it not "push" the diode's anode voltage around relative to ground? And in turn, would that not push the base of the pass transistor, which pushes on the emitter?
Thanks, tangent. I appreciate the vote of confidence... no, really. |
