Originally Posted by Magsy
So you own one?!!
$160 is ok, I paid $140 for my 0404 in the uk!
How does it sound and what do you have as a reference? Does it do 88.2khz too?
My previous setup is as follows:
Digital (spdif) soundstorm input to Yamaha RX-V430 (AVR) running monitor audio bronze 2 front speakers (with a bunch of other small speakers for surround and centre when watching dvd or gaiming).
When listening to audio, somehow I have this feeling that certain instruments are missing or not so defined. Usually I pumped up the higher frequency in the EQ (both nvidia software and on the amp). Somehow, the sound quality did not sound the same when I was auditing the speaker at the audio shop using audiophile amp and cd player.
With the onkyo sound card, everything sounded just right with flat setting. Vocals and soundstage are improved and it sound as good as when I audited the speaker at the speaker audio shop. (Take this with a pinch of salt as it was about 2 yrs back).
Anyway, the sound quality from the Onkyo can't go wrong with the quality components used.
The line out ( dedicated 2 channel via DAC WM 8716) also sounded much better than the front out (7.1) from DAC WM8776. I can always hear the difference when blind folded after I toggle between these input to my AVR.
Anyway, all these comments are subjective. By the way, the card is able to output spdif, 2 channel line out and 7.1 all at the same time.
Spec defined 88.2 supported but I cannot find any setting on the VIA drivers with this selection. So cannot confirm.
Anyway, I will try out if the drivers from prodigy 7.1 works with this card tonight.
