Kang
- Aug 11, 2007
Has anyone heard the new Omega O2 MK2? How does it compare with the previous O2 model. Apparently it has improved wiring. Thank you.
Originally Posted by Kang /img/forum/go_quote.gif Has anyone heard the new Omega O2 MK2? How does it compare with the previous O2 model. Apparently it has improved wiring. Thank you. |
Originally Posted by mikeymad /img/forum/go_quote.gif I came to the conclusion that I didn't need to get rid of my O2's and buy a new Mk2. But if I didn't own any, I would just buy the newer Mk2. |
Originally Posted by Piotr Ryka /img/forum/go_quote.gif First of all this two headphone systems (Stax Omega II & Mk2) are the most cable depend of all. You use another interconnect, you get something quite different. Almost the same with power cables. So, as well both could be warm or cold. However: -Omega II is more warm than Mk2 -Omega II put accent on the middle of the stage -Omega II is maybe (I am not sure) more transparent -Mk2 has wider soundstage -Mk2 has more powerful bass (quite good indeed) Both are fantastic. Forgive me my English. |
Originally Posted by Piotr Ryka /img/forum/go_quote.gif First of all this two headphone systems (Stax Omega II & Mk2) are the most cable depend of all. You use another interconnect, you get something quite different. Almost the same with power cables. So, as well both could be warm or cold. . |
Originally Posted by ironbut /img/forum/go_quote.gif Piotr, could you be a little more detailed about the cables you've tried. Also, about how many hours do you have on the Mk ll ? |
