YoYo JoKeR
- Feb 17, 2013
I too feel your unit is defective. Just return them, get a replacement (or refund, if you like to go for other cans)
Fair enough. Do they sound tinny and artificial to you, though?
I'm very confused when I read endless reviews about a headphone being (relatively) accurate, but then have the opposite experience when I buy it.
If anything, their reputation for accuracy is off because they have a bit more bass than a neutral headphone should.
Then my pair is most likely defective. Even when I use EQ to increase the bass to maximum, there's hardly any bass at all!
Unfortunately, I spent all the money I had left over on the headphones, so now I can't even pay to send them in for a replacement (or refund) until I get more money.
By the way, speaking of the XPT100 quote in your signature, I just put them on (with no music playing) when there was external noise, and I didn't hear the noise at all!
Yep. They are pretty darn isolating
So did you notice any of the problems I mentioned? Or were yours nothing like mine?
They are not mine. They are my son's. I have not listened to them in a while.
If you hear them again in the near future, let me know if they sound tinny or artificial to you at all.
My son spends the school year at his mom's house in another state. So not likely.
The XPT100 is the same drivers and cups as the Brainwavz HM5 and Fisher FA-003, so same sound. There other threads for those on Head-Fi where you might also seek advice
I'm guessing you have a lot of experience with much more expensive headphones. But I agree with you a lot of the popularly recommended headphones turn out to be gimmicky -They may have quality in some way but overall they tend to be uneven.
I am curious though which headphones you liked in the under 150 or 200 dollar range. I was thinking about getting the M40x but your review really throws a wrench into it. I kind of assumed the XPT100 was a gimmick already especially with those giant earcups.
Dammit now I don't know what to buy.
Also of note if we're comparing M40x and XPT100 to your QC15's, your QC15's are much more forward with accentuated bass and treble not to mention much much more expensive.
Hey there!
Sorry for the late respond (as I just read your email). Is it possible for you to list down some tracks that you find your headphone to be dry sounding?
There are many possibilities than can cause what you are listening now:
- the cable jack was not soldered properly (if possible, try it with a different cable. I believe there is two cable included right?)
- behind the driver of HM5, there is a foam that prevents reverb and I believe it keeps the bass alive as well (?)
- you have not set your EQ back to neutral yet from last listening
- your headphone is defective.
Either way, feel sorry to you as having such terrible experience twice with headphones :/ but the HM5 sound accurate to me.
Hope it helps
Billson
But basically, it sounds like someone turned the bass all the way down and the mids and treble all the way up. Doesn't sound accurate at all. I listen to all types of music, and I know the recordings have far more bass than my XPT100 is reproducing.
What amp are you using? I just tried running them off a Talisman T35HP and it sounds awesome. Granted people generally don't use $1K amps with $120 headphones, but they scale very well.
