- May 29, 2006
So perhaps I shouldn't try that again...
Thanks for the heads up on that potential disaster.
Headie - thanks for that comprehensive answer, it seems quite clear.
Originally Posted by ericj /img/forum/go_quote.gif Keep in mind that the T-Amp's output is balanced, and you can damage it by trying to force it to run single-ended. Also that it's designed to drive a 4-ohm load, and the frequency response and distortion curves will get very weird if the load doesn't at least look like something in the neighborhood of 4 ohms. So, put a 5 or 6 ohm 10w resistor in parallel with the headphones. |
