mlchang
- Feb 28, 2002
If you look at the schematics of the pocket headphone amp (or any of the other designs based on op-amps) you will see a line from the output of the op-amp back to the negative input of the op-amp. Usually has a few resistors in between (which set the gain). This is the local feedback loop.
A buffer is another kind of IC like an op-amp but it doesn't provide any gain. It's just there for current purposes, to provide drive for the headphones, but not actually amplify. It gets its input from the op-amp.
So you can place buffers outside the local feedback loop, meaning the output of the buffer doesn't feedback to the op-amp, inside the local feedback loop meaning the output of the opamp goes to the buffer (without feeding back on itself first) and the output of the buffer feedsback to the op-amp (aka global feedback), or you can do a multiloop where the output of the op-amp feeds on itself, AND the output of the buffer feedsback to the op-amp. The multiloop design is like the circuit on the META42 printed circuit board. It is supposed to minimize errors from the input and output side of the op-amp.
Again, please correct if this is wrong.
