Odd CMOY Grounding problem
Jun 15, 2003 at 9:10 AM Thread Starter Post #1 of 3
Frank
finally finished the amp today. but i get really bad hissing. oddly, to fix the hissing i just disconnect the left/right channel output clip and touch it and the interference hissing goes away and im left with a perfectly clear connected channel and a humming disconnected channel. the moment i plug the channel back in, the hissing starts.
whats going on?
my power caps are 470uf 25WV's
my signal caps are 0.1uf 100V+
all caps are running off 2 9v batteries. other than that, everything else was built using tangents cmoy tutorial.
Jun 15, 2003 at 1:29 PM Post #3 of 3
would it matter if i was using a different opamp than the listed one? (different tolerances)
so far, im using a cheapo opamp to test if i did the soldering right.
