xnor
- May 28, 2009
Headroom of the O2 with 2.5x gain and power supply and a 2V source is about 3 dB, so the source may output up to 2.8 V RMS or 7.92 Vpp.
If this is not what you mean with headroom then you really should look up the term before using it. It has a clear definition.
Sound stage in headphones with stereo recordings? Not unless you do quite a bit of signal processing. To perceive real sound stage in front of your head you at least need crosstalk (some bad amps have lots, yay, but usually still not enough) and interaural time delay, both of which is a given with speakers. Sure there are binaural recordings for headphones, but there are not many.
With headphone listening, all spatial cues are in the recording but they are largely influenced by the headphones. Again, open type headphones provide more crosstalk, but what I'm talking about is stuff like frequency response peaks or resonances or loose bass due to bad damping factor etc. masking these cues.
Detail. Have you looked at the O2 measurements? It's high nonlinear distortion and noise floor that swallow details, both of which the O2 is devoid of.
Oh and the low output impedance helps in that regard as well.
Could you answer #536 please, so we can look if the amp you're preferring is indeed superior in all those regards?
By all means, demonstrate the machine that measures things like headroom, soundstage and detail.
