Can Junkie
- Jul 19, 2012
This may be old news for some of you and it is not unlike the black rubber band trick.
The UDAC does not come with any small rubber feet and the unit is so small that any tabs on the bottom might look like over kill. I got tired of it slipping around on top of my amp and I wanted a little protection for both units. I went to a hardware store and bought a two O-ring rebuild kit for a faucet. Costs less than $3. I pulled the two O-rings over the UDAC and placed them just behind the front plate and just ahead of the back plate. It looks really good and even looks like part of the end plates. My UDAC no longer slips around and both it and the amp are protected. The fit is tight enough that the rings do not roll around on the unit. (size of O-ring must be such as to make a tight fit) This mod might even work/look good on larger units given larger O-rings.
