A couple more things ...
The parts list suggested using 2 22uF caps while the board says to use 10uF caps. If you already have the 22uF caps, they should not cause a problem, but they have been replaced on the parts list with 10uF panasonic FC's.
If you are using tantalum 1uF caps instead of the Wimas, please note that the tantalum caps are polarized. To figure out how to install them, each position has one leg toward the 2902, and another to the ground plane. Connect the positive (+) leg of the cap toward the chip and the negative (unmarked) to the ground plane.
I built one and plugged it into the computer. No errors, no smoke, etc. I didn't hook it up to a DAC yet to see if there is a signal as I am waiting on some wire to do this with.
