blipblop
- Dec 6, 2003
Once again, I'm sure I'm merely illustrating my ignorance, but...
So far, the various incarnations of the PPA I've seen around these boards all make use of a regular switch - a conventional toggle, pushbutton, or even a momentary switch (with added circuitry) - to power on the PPA.
Has anyone used one of those devices that combine volume control and power-on in one mechanism? I don't know the name of it, but its quite popular on car radios, where the radio is turned on by turning the volume knob, where physical resistance is felt as the radio is turned on, and then the knob is freed to turn for volume control.
I thought this would be a great idea since (1) it would eliminate the need for two seperate parts, and (2) would eliminate the risk of turning on the Amp with the volume cranked up, and blowing out one's ears (i've done this before and it hurts!).
Perhaps its already been discussed here, but I haven't seen it or don't recognize the proper name for it, if infact, it has been discussed.
