Pageygeeza
- Dec 1, 2009
Hi peeps,
I've posted on here a few times already, but now I'm after some information that's been bugging me ever since I found out about "Cmoys". There are a staggering amount of different diy instructions for Cmoys, but I just can't differentiate between them all.
I've made my own Cmoy using these instructions and came up with this:
Though it does a good job of increasing the volume, I can't help but feel it's not good enough. I do also have a CmoyBB as well and love the sound from it.
Now here is the problem: I want to make a 9v low drain portable amp for headphones that range from about 30-40 Ohms. I know there are countless capacitor combinations and would like to know what the optimum selection for components are. I've also noticed that some designs have buffers integrated too, does it have a positive effect on the audio output? I've also found this and like the idea of the eq on it. Has anyone ever made it and is it any good?
Basically I use an 80gb iPod classic and listen to pretty much anything, so it would need to be a great all rounder. I'd love it to sound pretty natural, but maybe include the eq to allow me to mess with the audio whenever the mood takes me.
I can't help but feel I've missed something out.
Thanks in advance people.
Edit:
Do the buffer power pins need to be decoupled with caps if I'm using the TLE2426 virtual ground driver?
Edit:
