Noobie need help with soldering mmcx male
Sep 10, 2020 at 11:06 AM Thread Starter Post #1 of 6
alibb
Singapore
I’m new to this. I initially wanted to solder my cable to 2 pins connector but my 2 pin IEM driver broke.
MMCX have 3 “pins” which is to “+” and which is to “-“? Or it doesn’t matter? Will a cable with mic affect the soldering?
Sorry really noobie question here. I tried searching online for wiring instructions but found none. (Except for the female one) I want to solder to the make. Maybe I didn’t look hard enough, would appreciate your help.
Thanks.
Sep 10, 2020 at 3:08 PM Post #2 of 6
Sep 10, 2020 at 4:29 PM Post #3 of 6
I always use a tone tester to map an existing cable as I build a new one. Mark down your notes and also test the connectors to see how they are rigged up. Makes life easy.
Sep 19, 2020 at 1:04 PM Post #5 of 6
Did you get your cable wired up?
Oh, yes, thanks a lot for the information!
It was a painful and frustrating process ... even with flux ...
In the end, dad has to help me as I just keep screwing up... LOL!
Very satisfying though at the end of it!
I'm glad I "saved" the earpiece which driver kapuut due to water damage ...
Thanks to you and @Voxata!!!
Sep 19, 2020 at 1:23 PM Post #6 of 6
Thanks for your advise!!
I haven't had the need to use those tools.
I was lucky in many ways and got the job done ...
after struggling with the sodlering though LOL
