roadbuster
- Oct 15, 2004
Hello,
Does anyone have a quantitative measure of the noise at the output of a "cmoy" amplifier using an OPA2132PA (or similar) op-amp? I just threw the basic circuit together using good quality components and I'm getting, in my opinion, a significant amount of noise on the output line (on the order of 100mV) when there's zero input signal.
Considering the amplifier is nothing more than a non-inverting, positive-gain amplifier with a low-pass filter at the input, I wasn't expecting particularly good performance. The noise can be mitigated using 0.1uF bypass capacitors between the supply and virtual ground rails, but it's still high enough to make me wonder whether this is common or just an issue that I'm facing.
Anyone have any experiences to share?
