Noise in my IEM
Feb 15, 2023 at 2:39 PM Post #18 of 26
Well, I suppose as long as you don't want to use the kind of phone it wasn't designed to work with, it's OK. But it's a lot easier to just buy an inexpensive DAC that sounds just as good and works with anything.
Feb 15, 2023 at 3:05 PM Post #19 of 26
Well i tested it with an LG G8x, works fine, no noise.
mojo is prone to noise from source, especially if you have sensitive IEM's. Even though I hear no noise using laptop --> mojo --> headphones I get a way better performance by replacing source with something like PI2AES. Similar case with Qutest, maybe that's the cause of aggressive filtering when the source is noisy
Feb 16, 2023 at 12:26 AM Post #20 of 26
Ritually burn all of it, then buy a carrier pigeon and a DAP.
Feb 16, 2023 at 12:27 AM Post #21 of 26
Send the pigeon to order a pizza!
Feb 16, 2023 at 3:31 AM Post #22 of 26
Also wrap the pigeon in alfoil just to make sure you don't get any more interference.
Feb 16, 2023 at 5:50 PM Post #24 of 26
What kind of phone are you using? And what kind of headphones?
