KusabiKuri
- Sep 23, 2015
I just recently got mine and have been using it with my Note 4 as well as my work and home laptops. For IEMs I tried my JVC HA-FX700s and for headphones I used my Mad Dog Pros. For speakers, I piped them in to my Audioengine A5+ set.
Initial impressions are that it seems with IEMs you get some white noise which is probably what the above poster was talking about. With the Mad Dog Pros, I get none of that. Sound-wise I don't feel like it's terrible but it's definitely not a huge step-up from internal DACs. Not having a clip on the unit itself also makes cord length a little awkward if you're not using short-cord IEMs. Maybe a MiniDisc-style removable clip would be helpful here. Also, I have not upgraded the software yet as detailed by the kickstarter page, but the volume control when plugged in to a PC and using the on-unit volume control is absolutely horrid. It has worked correctly for me exactly once. The volume stays at something like 40-50% and you can't raise it, only lower it. When in USB mode, your computer cannot control volume so you're forced to control it via the unit or a secondary amp (which was a non-issue when plugged into my speakers).
All in all, if they fix the volume-control issues and the background noise with IEMs, I'd probably use it more. Until then, FiiO's offerings for the slightly higher pricepoint are definitely more polished and reliable IMHO.
