ozshadow
- Apr 29, 2006
What a Tread can do depends primarily on the wallwart power supply you use. A tread just regulates it and cleans up the signal.
Originally Posted by ozshadow What a Tread can do depends primarily on the wallwart power supply you use. A tread just regulates it and cleans up the signal. |
Originally Posted by Heady I've got a question which is related. How much current can a Tread supply? Can it be used for a power amp with the appropriate bridge rectifier and voltage regulator? |
Originally Posted by tomb Steady state operation is still well below 1000ma, but somewhere above 500ma, I think. Regardless, the inrush is high enough that several LM317's have been blown on TREAD's and STEPS' supplying M3's - lots of power in that amp. |
Originally Posted by Teerawit It really depends on how high your bias settings are. Also, the inrush on my LM317-equipped STEPS has never killed my M3. I don't think anyone should be worried about the M3 causing their STEPS/TREAD regulator to blow up. The real issue is what happens when you turn off the amp. |
Originally Posted by tomb Bias settings are steady-state (if not the definition of). It adds a component to the load, but inrush current is largely determined by the need to charge capacitors. |
Originally Posted by Teerawit Um, I was referring to the bias settings determining what your current draw would be. 500 mA is way up there. I think the default config draws more around 300-350 mA. |
Originally Posted by ozshadow Yes, I was referring to the tread layout. Tangent gives lots of options for customizing it to fit your needs. |
