If the RS 130 is constantly hissing, maybe you have not set it up correctly.
Firstly - The battery should be charged for 24-hours before first use.
Secondly - Connect the transmitter to a headphones socket and the volume should be set *loud*. Not so loud as to cause distortion in the transmitter, but louder than normal listening level.
Setting the level high to the transmitter, means that you are transmitting a good level and the transmitter is fully modulating.
Then, the volume on the headphones can be set much lower.
This minimises any transmission noise.
Low level to the transmitter + high level on the headphones =
High level to the transmitter + low level on the headphones =
Also, please be aware that about 3/4 of the price of any wireless headphones is in the wireless part - the transmitter and receiver.
Sennheiser *did* once make some superb cordless headphones where the whole transmission was digital and the DAC was in the headphones. Quality was superb as the headphones were the HD 580 - but the digital wireless version was x4 the price and people preferred to buy the wired headphones and spend the £600 they saved on a good headphones amp and still ahve money to spare - unfortunately.
