Jasper994
Organizer for Can Jam '09
- Jun 3, 2003
I think the only real correlation is the distance between instruments in the soundstage. The exception being if the soundstage is compressed in height, width, or depth in a manner where one is disproportionate to one or both of the others. Think of it like a 3D picture. Soundstage represents the total size of the picture, however big or small. Imaging defines the placement of each thing inside of the soundstage. If imaging is accurate, things will be placed properly in the picture and it will be easy to identify where something is placed. If imaging is poor, it will be difficult to determine exactly where something is in the soundstage. In the case of the Super.Fi 5 Pro, I feel the soundstage is expansive, but that the imaging is less precise than the E4 which has a smaller soundstage but better imaging. If separation is good, two or more things that are close together will maintain their individuality. Poor separation will blend sounds together.
Originally Posted by Spyro On a lighter note....what is the difference or correlation in "soundstage" versus intricate and distinct separation of instruments (left, right, far left, far right, etc)? Thanks. |
