Newbie needs help
Mar 7, 2018 at 6:27 PM Thread Starter Post #1 of 7
tidytrev
Hi guys, I'm taking my first step into some decent headphones, I'm coming from some cheap and cheerful cans and I'm on a budget of £150 for headphoes/amp I know that's not much but it's all I have.
I'l be listening to a wide range of music and gaming with them, I had my heart set on the Beyer dt990 250ohm and a fiio e10k amp and that fit nicely into my budget but if read a lot of conflicting reviews on the combo with most saying the amp won't drive them to there potential.
Any input and suggestions is highly appreciated
Mar 7, 2018 at 6:42 PM Post #2 of 7
It's true that it won't drive the headphones to their **full** potential. But 250 ohms is not too much for e10k. It should be a nice starting combo if you want to go portable.
Plus this leaves improvement opportunities for the future ... :-)
Mar 7, 2018 at 6:47 PM Post #3 of 7
Alternatively, see if you can stretch your budget by buying used or open box
Mar 7, 2018 at 6:50 PM Post #4 of 7
Thank you, anyone got suggestions in the £50 region for something better amp wise? I don't want to have to sacrifice the dt990s just because I can't afford a super expensive amp
Mar 7, 2018 at 7:34 PM Post #5 of 7
Topping NX4, though this is a bit over budget. If it doesn't have to be portable, I would consider the Bravo v2 tube amp.
Mar 7, 2018 at 7:37 PM Post #6 of 7
I don't know about better, but if you need something a bit more powerful, for less money, and you don't mind it being an amp only (no DAC), the Walnut F1 is very cheap and will drive pretty demanding headphones.
