Newbie: EMU 0404 software properties for better sound?
Jun 7, 2005 at 12:35 PM Thread Starter Post #1 of 3
idanhakia
ok i just recieved my EMU 0404
what kind of software do i need to install to get a better sound quailty.
what is ASIO?
i installed it into FOOBAR2000 v0.8.3 and i only recieve a ERROR message
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://F:\Mp3\Full Albums\Shpongle\Are You Shpngled\06 Shpongle - Divine Moments Of Truth.mp3" (0)
INFO (foo_output_asio(dll)) : open : 96000 Hz, LINEAR PCM, 24 bits, 2 channels
INFO (foo_output_asio(dll)) : ASIO device type [channel 0] : Int16LSB
INFO (foo_output_asio(dll)) : ASIO device type [channel 1] : Int16LSB
ERROR (foo_output_asio(dll)) : unsupported output data format.
what more modification do I need to do to work it out?
10x
Jun 7, 2005 at 2:30 PM Post #3 of 3
I guess you'll need to create a PatchMix session with 96 kHz for this to work - currently the card seems to be set up for some other sampling rate. ASIO is best looked up with the search engine of your choice.
