plainsong
Headphoneus Supremus: Untie!
- Dec 4, 2002
I'm no fan of the hd595 by any means, but let them play for what, 200, 300 hours before deciding on the sound. Also avoid quick testing from one to the other (called A-B'ing) for now at least. Once they've burned in or are close enough for jazz (I can usually tell if I'll like a headphone or not, even if it has that new headphone harshness, but that's hopeful listening), then use them for a while exclusively.
Then try going back to the ibuds or whatever it was you were using before. Now there should be a difference.
That said, the ability of a source to drive a headphone has little to do with volume and more to do with everything else. That's tough to describe unless you compare the two, but one can be headache-inducing and the other not. You can give a pig diamond earrings, and it will still look like a pig wearing diamond earrings. Get it?
Or send them back and get some A900's or something. I would.
edit - Miss Piggy excluded of course.
screen cap from her latest charity work on Extreme Makeover Home Edition. The world needs more Muppets!
