yeah i will let you know once its done, but i was searching around and found this great kill switch idea that i'd like to incorporate.
i would like to add a momentary on/off switch to cut the signal from the guitar to the amp, ive found some information on how to do this but mostly all of them use TRS (or stereo) plugs with a tip and a ring and i was wondering how i would wire this switch into female jack thing...
here is a picture if you need more information just ask.
here is the part numbers on radio shack of everything i will be using
2751566 = momentary on off switch
2740252 = female 1/4 mono jack
2062397 = piezo buzzer ( i will remove the piezo transducer from it)
anyways ive seen youtube videso where they wire the tip and ring of there guitar cables to the momentary button and this somehow works to mute the signal could someone explain this too me?
edit okay, i added the switch to the drawing, and im not exactly sure how this switch works but im assuming theres an input and output little tab on it so would attaching the wires to one tab and then connecting the other tab to the jack work, take a look at my picture here...
