Originally Posted by Soundbuff
I switched over to the Plextor drive and it IS faster in secure mode. Only about 10 minutes for the CD it is ripping now.
Do you have any other tips or recommended changes to the settings for EAC? For example, is MP3 best or is Ogg a better way to go?
What's that whole deal about "alt - standard", "alt - medium", etc. that I saw on that one link recommended above...should I mess with that setting?
Plextors should be fine with returning errors, and they don't cache audio.
Format and quality is an issue for you to deal with.
FLAC allows those deicisons later, but is huge (300-500MB per album).
LAME --preset standard is generally considered transparent.
--preset extreme is a bit above that.
--preset medium will be smaller than standard, and well-suited for portable devices.
Ogg Vorbis (Vorbis is the audio--you could make a Ogg MP3 if you wanted) is nice for low-quality stuff, or good ears, as it does not deteriorate harshly (so, if an MP3 is not transparent, a Vorbis of similar quality would sound better to your ears). For portables, though, it will consume more battery life at a given quality (as will AAC, if you're an Ipod type).
You won't be getting 15+ hours from that U2 with Ogg.
If you want losssless, FLAC is a good way to go. A couple others can get smaller, but FLAC is already gaining portable support, and can be played on any platform. Also, you can get it made into another format later, without re-ripping the CD. Since going between documentation can be a pain, and FLAC is very bad about giving you errors it encounters, here's a string to use if you want to try out FLAC, and not spend too long getting it working in EAC
Code:
Code:
[left]-8 %s -o %d -T album="%g" -T genre="%m" -T artist="%a" -T title="%t" -T tracknumber="%n" -T date="%y"[/left]
