Night and day sound wise is the feeling i got when i compare my bass problem 306 vs the ifi gryphon and Ru6. Gonna try the 707 tommorrow.Night and day? Lol that sounds like the capped one I had with the bass problem. He's doing the best thing, he's going to try them himself. Not saying they don't sound better or different, but I've never had any night and day experiences in daps. Not with stuff relatively easy to drive. The closest was tube amps and r2r, but I wouldn't call them night and day just distinctly different sounding. But most daps sound similar to me unless ones got more power and the iems/cans need it. The capped one that was maybe defective, yes that sounded weak.
New Sony Walkman NW-A300 Series (Android 12)
EvilJesus
- Nov 13, 2014
And that's why it's all subjective. Opinions will always very.Night and day? Lol that sounds like the capped one I had with the bass problem. He's doing the best thing, he's going to try them himself. Not saying they don't sound better or different, but I've never had any night and day experiences in daps. Not with stuff relatively easy to drive. The closest was tube amps and r2r, but I wouldn't call them night and day just distinctly different sounding. But most daps sound similar to me unless ones got more power and the iems/cans need it. The capped one that was maybe defective, yes that sounded weak.
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
No kidding, your talking about -10 db cut in the lower frequencies. Anything with a normal frequency response is going to sound much better. That's (night and day) expected when your comparing Apples (defective items) to oranges- items that are working normally.
Maybe he's got a defective one, that's what I was alluding to. I doubt many would be able to tell different sources properly volume matched with no dsp on the same iems. In a blind test. Even the cheapest dongles today have stellar audio performance. Just daps usually have better output sections, amping, caps, and more power available. Things are colored somewhat, sometimes because pure neutral can be a bit boring with some gear. But usually it's not excessive. Everybody hears things different and we all have bias. So really all you can do is listen for yourself and if you care you can check measurements for many daps and dongles. It doesn't really determine sound quality but at least you know how the circuit is performing and how much Imd is present and how clean the output should be under a minimal load. Or sometimes measured under a normal load and FR of cans or earphones, iems. Plus jitter and other factors. Alot of this stuff is inaudible especially in super high or low measurements, and is just bragging rights and feel good specs.
But you'll find that stuff that measures poorly often is wildly popular and praised. And stuff that measures highly sometimes is too neutral or flat for users. Especially depending on what gear they're using to listen with - iems, headphones.
Best bet, listen for yourself. Take all this with a grain of salt.
abitdeef
- Oct 30, 2003
True my friend, our best tools are our own ears.
Came to a fantastic Shop in Seoul today called Scheherazade and tried the A306. The first unit was considerably different sounding compared to the demo unit. The new one had no bass and the volume was lower. The guys had no issue to get me a second one which sounded exactly like the one they had in demo. Really nice player and I was open for any of the new players but after using them side by side I picked the small one.
goody
- Apr 2, 2009
It will sound lifeless and dull no dynamics trust me your ears will let you know ..i wouldn't botherHow you know if the A-306 is volume capped?
psikey
- Jul 15, 2008
As some one who owns both, it all comes ...The difference between the 306 and 707 with my Cascades and Mammoths is night and day. The sound stage, bass and overall audio performance of the 707 is better.
Glad for you, but I've come down from WM models to the A307 and over 3.5mm certainly not night & day for me, and mostly agree with abitdeef. Thats assuming the ZX700 series isn't audibly better than the WM models and driving easy drive IEMs.
Not commenting on 4.4mm balanced though.
Monerjoner
Did they have the 307 for saleCame to a fantastic Shop in Seoul today called Scheherazade and tried the A306. The first unit was considerably different sounding compared to the demo unit. The new one had no bass and the volume was lower. The guys had no issue to get me a second one which sounded exactly like the one they had in demo. Really nice player and I was open for any of the new players but after using them side by side I picked the small one.
It’s definitely uncapped thenIt will sound lifeless and dull no dynamics trust me your ears will let you know ..i wouldn't bother
wait what's the difference between the 306 and 307? is that just a typo?
Zaroff
- Mar 10, 2004
32gb vs 64gb internal storage.wait what's the difference between the 306 and 307? is that just a typo?
Do you have a source for this? Last I heard what that this was from a more informal phone conversation and they put nothing in writing. Until it's in writing it means nothing.Yes Sony has identified it as an software issue and is going to fix that via firmware update
Question regarding volume capping in EU/UK
Is there a way to measure this or is the capping referring merely to any possible warning when increasing the volume?
How does this audio capping manifest?
I'm asking because the UK version I have doesn't display any warning (visual or otherwise) when increasing the volume to 120 and leaving it there for several days, is there a way to check the volume capping?
Is there any other difference in comparison to the Japanese version?
Thanks
Thanks
I asked the same but apart from the message here I haven't seen it anywhere.Do you have a source for this? Last I heard what that this was from a more informal phone conversation and they put nothing in writing. Until it's in writing it means nothing.
Btw willmono7 I've sent you some questions via PM regarding the version in particular that you bought, thanks!
